RCU Forums - View Single Post - Extreme Flight 87" Yak 54 - Build & Fly
Old 09-08-2005, 01:39 PM
  #5997
JWilliams
Default RE: Extreme Flight 87" Yak 54 - Build & Fly
I do the KE spin with my yak out of blenders mostly because it is just another way to show diversity as the plane descends. But it is easy to do, I just get the plane in a ke and cut the power till it starts to descend then come in with aileron and down elevator on 3D rates and just bump the throttle off idle. The required aileron may be same or opposite depending on the plane. I cannot say how much aileron, elevator or throttle to put in but you will need to finess this some and play with it to see what your plane wants. Start high as these KE spins cause excessive altitude loss quickly. Now, the most important part, how to get out of it once you are in it. You can let the controls go neutral and it will come out, but you might not like how it does it. I just cross my rudder to the opposite side I was holding and it will go into an inverted flat spin and once the altitude loss stops I add throttle and begin releasing the inputs so it flies out of it. Play with this and you will get it.
Jeff
