ORIGINAL: LarryC
I have a garden tractor battery that I bought from the local big-mart for less than $20. It sees a lot of use running starters, charging small lipos, etc. It works well for all of these things, so long as you remember to recharge it after charging lipos.
Does anyone know what the amp-hour rating of this type of battery is? They are only marked with a cold-cranking amp capacity.
Larry
There are quite a number of different batteries in the garden tractor class. Can you give us some numbers on yours?
