HAS ANYONE COME UP WITH A MODIFICATION FOR THE TAIL WHEEL SPRINGS??? I WILL NOT SET IT UP STOCK,WHY BURN UP A SERVO&LOOSE THROW BECAUSE OF SPRING TENSION? I HAVE THE SPRINGS AT THE BASE OF THE RUDDER ARM FOR NOW,HAD TO UN-TENSION THE SPRINGS A BIT.IT LOOKS LIKE IT MIGHT WORK BUT IT SEEMS TO LIMIT WHEEL ROTATION SOME.
Mixmaster,
I have modified the tail wheel with a small piece of aluminum stock and it works Great!
GK
