RE: F18 SM Gravity Center
Hi there,
just to back up B777 regarding the batteries in the nose. Use batteries of high capacity because you will need the weight in the nose. In total I ended up adding 1200g in the nose (all 3000mAh NimH cells). But don't worry the F-18 can handle the weight.
Best of luck/Johan
