RE: Overheating eFlight Brushless and ESC?
hello,
I just bought the park 400 3700kv brushless.....it hauls ass! I put it on a 36in minibee and it hits over 100mph in a dive and cruises strait up. here is my setup....2000mah 3s1p lipo, 18amp jeti controller, and a apc 4.2 x 4 prop. It draws around 19 amps..guesstimate.
if you have the higher kv motor you will need to use an even smaller prop...by the way...dont nose your wing into the ground with the throttle pinned! I broke the shaft off and had to order a replacement. I am going to work on customizing the broken one to have a larger shaft...will let you all know if it works out.
go faster
theharpman
