RCU Forums - View Single Post - tighting a prop nut?
Old 09-20-2005 | 09:07 PM
smokingcrater
Default RE: tighting a prop nut?
I've gotten some decent size wrenches on the nut before, and you can REALLY crank down most composite props without a problem. I don't know how you are tightening it, but there shouldn't be any effect on the bearings. the only thing to worry about is the nut, engine crankshafts are hardened steel, so the nut should strip first.
