RCU Forums - View Single Post - IMAC Kits
Thread: IMAC Kits
Old 09-21-2005 | 08:03 PM
EXCAP232
My Feedback: (12)
Default RE: IMAC Kits
As noted above the price will probably not be that different. It is possible to get a good deal at swap meets or in the marketplace here on RC Universe however. Many don't like to build. This is normally caused by not having good building skills. Once you gain skills it becomes more of a pleasure than a chore. I fly when the weather is good and build when it's bad so I enjoy the hobby all the time. I also fly ARF's but prefer my own build jobs.
All the kits mentioned are good. Add to this list Aero-Tech models and check out their forum here on RC Universe. I have an order for one of the 35% Yak-54's
I have built almost every manufactuere's kits. The construction methods will differ quite a bit. Carden is probably the most different of the kits. It uses little light ply as in most other kits. Midwest is the most traditional with all balsa and ply. Most use a combination of light ply and sheeted foam. Some come with the foam pre sheeted such as Columbo Anderson (also known as CA Models and available from Aeroworks). Sheeting isn't hard however does require some addtional skills. Had the Midwest Extra with a Quadra 52 a while back. I have a 27% CA Extra and it is quite nice. The 40% Carden is scheduled this winter. I'm flying a H-9 Extra-260 ARF and have to say I'ts one of the nicest ARF's ever encountered.
Build & Fly,
EXCAP232
