RCU Forums - View Single Post - Gremlin Help
Thread: Gremlin Help
Old 09-26-2005 | 11:02 PM
lbarnes
Default RE: Gremlin Help
Hey, when you get bored with the stock Gremlin, do what I did, cut the wings down to 38", put a .46 on it and use metal gear servos and have some fun.
I did get some flutter on the high speed passes and covered the gaps in the wing/ailerons wint some 3m clear tape. The metal gears and tape did the trick on the flutters.
With a .46 magnum unlimited vertical and very high speed level passes.
Didnt cover the wings with balsa, added a balsa LE and TE and then covered with Monocote and shrunk it with light heat.
Larry
