RE: Showtime
The trick with AXI motors is to use high voltage/high windings. I will run a 10s Kokam 3200 @ 20C discharge. 37 volts will produce enough poop for that 4130 at 8-9 lbs easily. My brother flys his 11-12lb Hangar 9 Corsair with a 4130 and it flys wonderfully.
I do have a 5320 but I'm saving that for my 12-13lbs Sukoi SU-31. That will require a 2p version of above.
That article in FLY RC mag has the Showtime on the cover!!
Thanks again fellas!!
Magoo
