propane solenoid
did I miss the page describing the orientation of the propane in / out line to the solenoid?
also, does anyone know if you can run the engine without the propane solenoid installed? or does the ECU sense the lack of its' presence and shut down?
(i.e. can I get the engine running with the solenoid plugged in externally and then unplug for operation?)
thanks
buck
