RE: G-62 quit running
I replaced the insulator block and the carburator. The engine still does not run. I prime it and it will fire once on each of the next four or five flips. Prime it again, and the same results. I set the HS needle valve at various positions from 1 to 2 turns open.
I did make sure the pressure port was open into the cylinder.
Any suggestions are welcome.
