Hey Mike, you're absolutely right, I wouldn't thin my HOK or Alsa paints with lacquer thinner, unfortunately ParmaPSE (the makers of Faskolor) do not offer a reducer, they suggest if you must thin the paint use no more than a teaspoon of water to one bottle ratio. The only time I really thin the paint (almost 50/50) is for doing very fine drop shadows, if your paint is too thick the shadows will be very grainy, it takes more applications but the results are much nicer. Mike, do you have a site? If you care, you can check my work out at
www.guraphicart.com
Cheers!
Rob
