RCU Forums - View Single Post - Extreme Flight 87" Yak 54 - Build & Fly
Old 10-14-2005, 01:50 PM
  #6154
jrjohn
My Feedback: (24)
Default RE: Extreme Flight 87" Yak 54 - Build & Fly
ORIGINAL: Aerohead
rdb127,
Be careful with the throw settings on the transmitter. According to Troy Built Models, the throws at the transmitter should not be set over 120% when using the Hitec 5955 TG. I have copied their cautionary note below. Apparently any setting over 120% causes problems.
Stand back! This is the most powerful servo in its class.
Hitec recommends 6v for giant scale use.
Do not use travel adjustments higher than 120%.
I don't understand why this warning is not plastered all over every Hitec ad.
AHead, are you sure your not talking about the 5995TG?
