RE: Airworld Hawk Building thread?
Main former placement:
The forward face of the second main former is 43 mm aft of the rear edge of the GTS exhaust hole.
The forward face of the lower edge of the former is 7.5 cm aft of the front edge of the rear wing retaining cross member.
The other main former will then line up automatically. The formers are not truly vertical but triple checking of inlets and jetpipe shows it all fits.
The aft face of the nose gear former is 2mm forward of the aft edge of the nose gear door cutouts.
I hope I am correct as they are all glued in with Hysol 9462. !
Regards,
David Gladwin.
