RCU Forums - View Single Post - Extreme Flight 87" Yak 54 - Build & Fly
Old 10-16-2005, 11:17 AM
  #6184
bpryor
My Feedback: (45)
bpryor's Avatar
Default RE: Extreme Flight 87" Yak 54 - Build & Fly
ORIGINAL: RVBlack
How much more will the DA50 weigh with a K&S tuned pipe on it compared to the pitts muffler?
That all depends on how you do it. A weight range would be 12-20 oz. A KS 60cc canister weighs 8 oz, and the header if made with KS stainless will weigh in the 4 oz range(w/coupler), plus whatever mounting system you use. Mine weighs less than an oz.....so assuming you keep the weight in the lower end of the range, you're looking at around 4-5 oz of additional weight. A properly tuned KS can should give you 300-400 RPM gain, which woud be 2-4 lbs of thrust....so obviously you'll more than overcome the weight with the additional thrust, but the question is a personal choice on the increased wing loading.
