RE: MW44 Starting Problems
'Start bad' relates to insufficient start rpm, you should check there is a good rpm reading on the data terminal and that rpm is sufficient for the start process to continue. Lower than 50deg rise in temp usually gives a 'weak gas' shutdown indicaton. Also check your Rx battery is freshly charged.
Rob.
