RE: AEROBIRD EXTREME MODS!
The ESC plugs into the port marked "throttle" on the RX. The two servos plug into the aerleon and elevator ports I think. Wierd thing is I had to use the "Delta Wing" mode on the computer radio instead of V-tail for both the Stryker and Extreme. Yes, in this mode one flap goes up and one down. This radio also has dual rates so now you can set the Extreme and Stryker for mild or wild flap movement. This plane battery plugs into the ESC and then the ESC plugs into the RX...providing power to the RX and servos. Then you have to other wires on the ESC that of course go to the motor. This radio is a brand new line from JR and for a 6 channel computer radio with it's features at around $150 it's a great deal. Radio also comes with it's own charge pack and charger so no more buying AAs. If you buy this radio and need help learning it just let me know.
