RCU Forums - View Single Post - GP Super Skybolt
Old 10-17-2005 | 10:30 AM
  #49
WYDAH
Default RE: GP Super Skybolt
Thanks k064as,
I do like how the yellow/black turned out. It's also quite visible at a distance, which helps with orientation. The canopy was tinted using the "Rit Dye Method". Do a search here on RCU and you will find a ton of info. Basically you soak the canopy in a dye mixture until you get the level of tint you want. It doesn't work with all types of plastics, and can be a bit messy, but it worked well for the Skybolt canopy.
Later.
