RCU Forums - View Single Post - Showtime for Pattern flying?
Old 10-20-2005, 11:18 PM
NJRCFLYER2
My Feedback: (42)
Default RE: Showtime for Pattern flying?
I couldn't bring myself to hard mount the engine, so here's a few pics of how I modified a Hyde A mount to fit the OS .91 going in the nose. I just used what I had, so this was originally a mount that fit an OS 1.40 RX. I cut the beam mounts supplied with the kit. Overall weight of the mount is 4.4 oz, which is acceptable I think. So this added about 2 oz from the stock beam mount weight, but I'm basically getting some of that back since this is going to have a 3 oz CF pipe to replace the 6.5 oz OS muffler Header weight is unknown, probably going to be under 2 oz and since I will use a teflon coupler system, that doesn't add enough weight to really worry about. Hopefully this will be a good setup. Thanks to Nat in La for a good deal on the ES pipe!
ID:	341811   Click image for larger version
ID:	341812   Click image for larger version
ID:	341813   Click image for larger version
ID:	341814   Click image for larger version
ID:	341815   Click image for larger version
ID:	341816   Click image for larger version
ID:	341817   Click image for larger version
