RCU Forums - View Single Post - Help a newbie with nicads
Old 10-26-2005, 08:04 AM
Mad Wax
Mad Wax's Avatar
Default RE: Help a newbie with nicads
I would charge both packs at 100mah for the first few charges, then once used them for a bit charge at 300mah for 1100mah pack and 200mah for the transmitter pack. You're probably discharging a bit too fast since it's a fairly low capacity pack. Set to around 300mah discharge. Do a cycle/capacity stored check (charge, then discharge and note down the amount the battery has stored)
