RE: 2-56 pull pull system
Just a tip that actually worked when I did it was if you rap around the coated wire together when you put it through the rigging couplers and use a ligther to heat it up it will melt and stick like glue and then put the shrink wrap on top of it.
just wanted to add " a great person personally Emailed me and helped me with that tip "
