RCU Forums - View Single Post - fg diff and output cup movement
Old 10-27-2005, 10:48 AM
radio_controlled_mad
Default RE: fg diff and output cup movement
ORIGINAL: chevyman_de
They do come with the CV drives as standard. Part number is 7080/3, Euro 1.90 for a set of four.
thanks - i will order some with the leopard,bit advice on fitting if you can - when the model standing still and the arms are at the straighest point is that the position of the most play in the drives - or should there be more play when the arms are moved,how much play should there be overall at the straighest point - just so i know when i come to fit them.thanks
