RCU Forums - View Single Post - fg diff and output cup movement
Old 10-27-2005, 12:07 PM
chevyman_de
chevyman_de's Avatar
Default RE: fg diff and output cup movement
Ok then, as long as you don't use 14mm square drives in rear, you can also put some shims/washers between the wheel axle's drive cup and the inner bearing to correct the play. Two normal washers for M8 bolts are approximately 3mm thick and should do the job. That's not exactly a correct replacement for the rubbers, just a band aid in case the inserts are not at hand.
