RCU Forums - View Single Post - fg diff and output cup movement
Old 10-28-2005, 07:24 AM
radio_controlled_mad
Default RE: fg diff and output cup movement
ORIGINAL: chevyman_de
Ok then, as long as you don't use 14mm square drives in rear, you can also put some shims/washers between the wheel axle's drive cup and the inner bearing to correct the play. Two normal washers for M8 bolts are approximately 3mm thick and should do the job. That's not exactly a correct replacement for the rubbers, just a band aid in case the inserts are not at hand.
i do have 14mm squares on the back as im also useing elcon alloy spiders on the wheels,the rubbers in both axle and drive cups are fitted - to shim the gap would take 3 washers on each axle to reduce the gap in the play,just dont think you should have to do that on £125 lower arms.
