RE: Why Why Why!!!????
are you re-tuning the motor every day.....you cant just leave the needles set at the same spot all the time and expect it to perform the same the day before
temp humidity all play a big factor. If high temps are a problem in high heat run a cold plug with higher nitro, it should help some
