RCU Forums - View Single Post - Extreme Flight 87" Yak 54 - Build & Fly
Old 11-01-2005, 01:34 PM
  #6287
bpryor
My Feedback: (45)
bpryor's Avatar
Default RE: Extreme Flight 87" Yak 54 - Build & Fly
ORIGINAL: JWilliams
I got carbon fiber gear for the 87" yak if interested. They measure 21.5 wide and 9.5 tall the holes are drilled for the axles and they will cost $69.95 each. Not sure on the weight as I do not have a scale, but they feel as light as the stock gear for sure. I am putting a set on mine as i wiped out my original gear on a flameout.
Jeff Williams
[email protected]
Yep, the set Jeff has fit the EF and KMP 30% Yaks and Graph Tech also made one for the 30% TOC Yak. I got my set for my KMP(same as Jeff's) and they weigh 8.8 oz, which is a bit lighter than the stock KMP gear and a ton stronger, but there is still a little flex so they shouldn't bounce too much. I'll have them on my KMP later today and will post pictures in the KMP Yak thread.
