David,
A case of 'using' you here I'm afraid to benefit from your potential misfortune
Would you recommend people get all the nose gear doors hinged and installed before installing the nose gear former woodwork? Looking at it last night, it would seem that there isn't much room to manoeuvre once the formers are in as you may be finding [&:]
What hinges are you using to hinge the nose gear doors? The moulded detail on the insides of the doors mean you can't just glue a hinge on it. The inside of the door will need a cavity created for the hinge?
Finally, do you know off the top of your head how much longer the nose doors need to be?
Thanks for all your help,
Mark
