RCU Forums - View Single Post - The Secrets of the snap???
Old 11-06-2002 | 03:53 AM
can773's Avatar
can773
Default The Secrets of the snap???
Originally posted by Don Szczur
I fly a Focus- this and other pattern planes I've flown... I use the following technique.
I increased the elevator throw quite significantly to get nice clean snaps. I've also used dual rate for snaps because of this. I go deep in the elevator, particularly at the start to give it a nice clean break. I normally leave almost all of it in throughout the snap (with my pattern plane, but not toc plane)
Second, I snap away (from me). Any heading change in this direction is less impact on the overall presentation.
Lastly, if its windy, normally snap with the wind- particularly on the 45 upline. That way the (weather vane tendency) corrects the exit. You are also better positioned for the next maneuver (reverse top hat) effectively.
Hope that helps.
Don
Interesting, more elevator, just goes to show that different planes react differently, the Evolis didnt snap worth a damn with lots of elevator
The snapping away from you really works as well, you can also be sneaky by leading the snap out then snap in, but I have only seen a few guys can pull it off with any credibility, most know who they are
