RE: Transmitter LiPo or NiMH
If you contemplate using LiPo in your transmitter, be sure that you can monitor the voltage under use to make sure it does not drop below 3 volts/cell. Also, for safetys sake, you need to remove the battery from the transmitter for charging unless you do not value the transmitter or its surroundings during charge.
