Old 11-05-2005, 09:15 AM
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
Default RE: whats the difference from regular and digital servos
Digital Servos are faster, More Torque, More reliable, Programable (hitec, which is the only brand I buy)
and give you a more authority over a plane in the air.
If you fly aerobatic aircraft and like doing 3-d manuevers, then you will see a big difference with digital servos, specially coreless digitals.
If you fly sport and warbirds, then you will not really see a difference.
Digitals are good for aerobatics, if you don't intend on doing this, then stick to non digitals. So I guess it depends on the application... which can be said for many things, e.g. aerobatic planes use light ultracote/monokote with very light high power-to-weight ratio engines. While warbirds use fiberglassing, paint, and generally fairly heavy engines for more scale flight.
