I did not use rite dye on the canopy av8tr. I used a black paint that I got at the LHS that is used to paint the inside of the electric car bodies. I think it was Patrics or something like that. The good thing about painting the inside of the canopy is that you can be as sloppy as you want and it will still look great. All you see from the outside is black, you cannot see runs or globs of paint that pool. It works great. Thanks for the link dude.
ORIGINAL: av8tr
Zippi, a couple of questions for you, did you use Rit dye to tint your canopy? And if you are looking for a good price on landing gear replacement you may want to check out
www.tntlandinggear.com. Tom uses mostly aluminum but can get or make pretty much any landing gear you need. Might be worth checking out.
Tim
