RCU Forums - View Single Post - Dual throttle cotrol
Old 11-12-2005, 02:16 AM
CP140
CP140's Avatar
Default RE: Dual throttle cotrol
Steve,
You can mix any "spare" channel to be slave to the throttle channel using one of your programmable mixes.... BUT.... the trim settings from the master (throttle) channel will not copy over to the "slave" channel. I suppose you could use endpoint adjustment in each of the two channels to adjust the idle points for each engine, but that might be a bit of a pain. I'm also not sure if the throttle cut feature would work on the "slave" channel.
You might want to try Airtronics Tech Support or the Airtronics Users Group on Yahoo to see if you can find an answer...
