Old 11-14-2005, 06:33 PM
Langster
Langster's Avatar
Default Unusual range problem
Hi All,
I have a 9x JR Tx and a 9 channel Rx. I have recently put the gear into an 80" Cap 232. When I am range checking with the aerial down an unusual thing happens. Although all other channels are OK for range even with the DA-50 running, at 2/3 of the normal range distance (with the aerial down) the elevator servos respond to controls with a delay. That is, one may operate OK but the other lags behind but still operates.
My only theory is that I am using regulated 6v for this plane and this may be too much for the Rx? I will reduce the voltage today and check again but had to quit last night due to fading light.
Any other thoughts?
Lang
