Old 11-16-2005, 11:02 AM
dirtybird
Default RE: Unusual range problem
You need to provide more information.
If you are using an FM (not PCM) receiver and IF you are have one of the elevator servos slaved to the elevator channel using say channel 6 output, it may be caused by interference that hits only the slaved channel. This is because channel six is further down the chain and more prone to be interfered with than channel two
