RE: Rumbling Bearings
OS does use some sealed greased bearings. My FS91 Surpass II uses one at least on the main rear bearing not sure about the front bearing. A 2 stroke it seems would be a better engine to use them on because oil doesn't need to get through the main bearing to oil a cam and it's followers and bearings. Both the main and front one would have to be sealed with grease.
