RCU Forums - View Single Post - ZENOAH STILL not pulling fuel ????
Old 11-18-2005, 09:50 AM
Rocketeer10
Rocketeer10's Avatar
Default RE: ZENOAH STILL not pulling fuel ????
Also check for positive pulse pressure from the engine crankcase. GT-80 has an airline attached for this, normal single cyclinders have a small hole feeding pulse pressure into the back side of the carb. THis hole or line might be plugged!
I once had a loose cyclinder head and that was enough to prevent pulse pressure from driving the pump diaphragm so the engine would only run a second on the raw prime squirted into the carb. Very frustrating indeed!
good luck!
GY
