RCU Forums - View Single Post - Foam Kit Building
Old 11-19-2005 | 05:12 PM
Reverse_Sensing
Default Foam Kit Building
Hey Guys, Im relatively new to foam combat aircraft building. As of late, my interest has grown and I would like to start building a foam fleet (2105 or 2610) of aircraft without having to buy a bunch of kits. After doing a little research, I have semi-concluded that I would like to attempt to build my own foam fleet from scratch using a hot wire cutter and the whole nine yards. As mentioned previously, I am 100% new to foam aircraft building and do not have any experience or the equipment required to start this process. If possible would any of you guys know of a couple good books or websites to get me started with everything I will need from building a hot wire cutter, to aquiring the right type of foam, and finally to building and shaping the specific aircraft parts. I'd appriciate all the help I can get, with all the experience already out there, it doesn't sound too unfeasable. Thanks for your time and help
