RE: My Forum
you may have broken out of myforums mode. if you select All Forums from the main drop down it takes you out of myforum mode or if you come into the forums from the homepage I believe you should be in all forum mode (not myforums). in those cases you will see posts from forums outside of your myforum selections.
