RE: Suggestions for a trainer plane
I don't know about first trainer plane H9 P 51 PTS It's a low wing MHOP You should start with a high wing setup
I have the P51 It's ok but I had three high wing trainer planes before, but low wing and tail drager was different and harder to get use to. H9 P 51 is hard to see with gray clouds or when the sun goes down you can loose it fast.
roltech
