Old 11-23-2005, 10:22 AM
mglavin
My Feedback: (31)
Default RE: Connector crimpers
The right crimpers for the job are paramount IMO, you'll find many available for the task some better than others. Professionals in this industry use crimpers that cost thousands of dollars there is a HUGE difference...
Special thanks to Simon Van Leeuwen for the effort to compile the following information:
Picked from inventory PN's that can be readily purchased from Digi Key, Electrosonic, Newark, Allied Electronics and be on your doorstep next day. Digi Key is probably the best in the shipping area; they have a next-day flat rate to your door):
REPLACEMENT 0.100" SPACING MALE/FEMALE CONNECTORS
NOTE: These housings, spring contacts, and pins will accommodate up to 20awg and feature a locking detent which means they will only physically separate if you unlock them (nice feature). Will handle 4.5A all day.
Description PN Comments
receptacle 104257-2
crimp spring contact 104480-9 30u" Gold, loose
plug 103653-2
crimp pin 104505-7 30u" Gold, loose
GENERIC 0.100" 3 PIN FEMALE CONNECTORS
NOTE: These were chosen to fit all receivers, so they are not keyed.
plug, 3 position 530554-2
crimp spring contact 531224-7 30u" Gold, loose
HEAVY DUTY LARGE SCALE 3 PIN CONNECTORS option #1
NOTE: These, and the following series, are readily available high-performance connectors able to handle in excess of 5A, yet are small and lightweight.
Receptacle 43645-0300 3 position (up to 12 pos avail)
crimp spring contact 43030-0009 30u" Gold, 20-24awg, loose
plug 43640-0301 3 position (up to 12 pos avail)
crimp pin 43031-0003 30u" Gold, 20-24awg, loose
HEAVY DUTY LARGE SCALE 3 PIN CONNECTORS option #2
NOTE: Not quite so readily available but are slightly smaller and higher performance. These are liquid proof, and offer detent friction lock mechanisms.
Receptacle 52213-0311 3 position (4 pos avail)
crimp spring contact 50148-8100 Phosphor Bronze, 20-22awg, loose
Plug 52266-0311 3 position (4 pos avail)
crimp pin 50147-8100 Phosphor Bronze, 20-22awg, loose
SPECIAL APPLICATION PLUG-AND-PLAY SYSTEMS
Plug, 8 position 172063-1
Receptacle, 8 pos 172070-1
Spring contact 170311-1 both housings use same contact
HIGH PERFORMANCE HOOK-UP WIRE NOTE:
Alpha 19/34 (19 strands of 34awg) TEFLON jacketed multi-color lead which is service-rated to 13 amps continuous (single lead, free air @ 30C ambient). TEFLON also offers the least mass of all the available jacket materials for weight critical applications such as F3B/F/J style aircraft. You can cut costs by choosing to buy regular PVC jacketed lead, but the performance specs drop off accordingly (8A max, increased jacket mass, bulkier). You will see a PN for this material as well. The PN's essentially remain the same, except that the color code changes. Replace "RD" with the color of your choice (black-BK, white=WH, etc).
Red, 22awg, 19/32 5855RD005 TEFLON jacket, 100ft roll
Red, 22awg, 19/32 1855/19RD005 PVC jacket, 100ft roll
Finally one caveat, an onboard control system is only as good as its weakest link...electrically AND mechanically. The above systems rely on proper crimping procedures (amongst other things) to ensure rated specs and mechanical integrity. Don't fool yourself, improper crimping is just as catastrophic as improper soldering.
