Old 11-26-2005, 01:30 AM
Langster
Langster's Avatar
Default RE: Unusual range problem
Thanks for the replies. I reduced the voltage to 5.7V from 6.0V and this has resulted in the range being 20% better. I was also informed that with PCM the channel that I was using for the slave elevator servo would take longer to decode so in fact this was indicating that the Tx was almost out of range. I accepted the 20% improvement with the voltage reduction and have flown the Cap 232 with no glitches or range problems.
Cheers
Lang
