ORIGINAL: kd7ost
If you can fit the crank higher though, it will help get prop clearance for those tactical fields.
Dan
Tactical Fields? You mean debris strewn, high grass, prop grabbing vine invested fields, right Dan?
The Landing gear Im using is really high, its also made by Dubro and is made from polymers, not aluminum so no interference to a low mounted RF antenna, not that any of that is going on this plane, I do have good clearance though!
Mike
