RCU Forums - View Single Post - Hinge Sealing Tape...
Old 11-28-2005 | 08:29 AM
Newc
Default RE: Hinge Sealing Tape...
Flyboy - By using one continuous piece of monokote for the stationary part - wing or stab - as well as to go over the hinge and the control surface you eliminate the step of putting on the clear monokote. I simply do the wing, then use a trim sealing iron when doing the gap - which I obviously try to eliminate when building, as do you - then put the monokote on the control surface as normally done.
