Old 11-28-2005, 11:24 PM
redfox435cat
redfox435cat's Avatar
Default RE: 4 aileron servos - need TX help
is it being set up as flaperons? otherwise use a third y harness hooked to the two y harnesses and hook it to one channel. you'll need the heavy duty harness.
I don't like flaperons on a bipe so i say hook one y to channel one to one wing and one y to channel 7 on the other wing. set channal 7 switching to null. and slave channel 7 100% to channel 1. Of course if your using flaperons mix to channel 6 and mix in flaps to your liking
