Old 11-29-2005, 05:38 PM
Pile-O-Wood
Default RE: 4 aileron servos - need TX help
With the 9303 all you need to use is the "dual" function. It will automatically disable the switch or Knob on the slave channel and it will rename the slave channel , so when you are at the field and need to change a mix you do not have to scratch your ### and try to remember which channel you mixed with the master.
