RE: servo extensions, ferrite rings & signal amplifier
Thanks for the input Rodney!!
You mentioned a procedure: "breaking in between the present connector and servo and splicing in an extension by soldering in the wires". Instead of breaking the wire and soldering, would it be better to simply replace the current 3"-4" servo wire for a 30" wire with no connections/soldering in the middle?
