Old 12-01-2005, 10:18 PM
AirmanBob
My Feedback: (14)
AirmanBob's Avatar
Default RE: do i need a pcm receiver with gas?
Well you don't HAVE to use a PCM receiver. You can set the plane up using your PPM receiver and work out all the bugs with that. But, chances are you are going to have trouble getting a decent range check with the PPM with the motor running. THEN is when you will decide you better try a PCM receiver. I tried to get perfection with my PPM receiver and couldn't do it. So I switched to PCM. It's what the experts fly, so its good enough for me too. Good luck and keep us posted on how the range checks go...
Bob
Dynaflite Super Decathlon...US41 engine...18x6-10 Top Flite prop....Futaba PCM....awesome!!!!
