Old 12-02-2005, 12:16 AM
TLH101
My Feedback: (90)
TLH101's Avatar
Default RE: do i need a pcm receiver with gas?
ORIGINAL: AirmanBob
Well you don't HAVE to use a PCM receiver. You can set the plane up using your PPM receiver and work out all the bugs with that. But, chances are you are going to have trouble getting a decent range check with the PPM with the motor running. THEN is when you will decide you better try a PCM receiver.
NOT True. I do not own any PCM receivers and many of my aircraft are gas. If you set up right you will not have RF issues.
