I change the shaft and bearing at the same time. I've never had to clean one. Many gallons of fuel, no cleaning. Change the shaft and bearing, works great, never cleaned and this ones got a few gallons on it since changing it out. but hey whatever works for you and your maxx is great! I don't see where its worth the extra few coins vs the headache's.
I'm done!
RN
Originally posted by mrmaxxman
i have about 14 gallons thru it so far and have only had to replace one way once and still have the original shaft. new bearing works great for about a gallon then i have to clean it.
also has anybody tried the aluminum starter gears from tower hobbies i did the port and polish on the trx 15 and its got a lot more power but its also a lot more tempermental until its up to
temp.
