RE: Radio check rudder movement
Update:
I forgot to mention an important part of the equipment. I have 2 elevator servos fead to a jr matchbox. I've isolated the problem, when the JR matchbox lead is removed from the elevator fead on th RX, all is well. Once the connection is made the problem returns. I've also discovered moving the matchbox around the rudder servo also causes the lots of servo movement. Seems the matchbox location is the culprit. How far does the matchbox need to be from the rudder servo???
Got his response from JR:
There is a chance you are simply swamping the receiver being too close to the model with the transmitter. Also have you tried outside in an open area or just inside your house/shop? The matchbox location should not matter. There isn't anything in the matchbox that could make noise so the location should not matter, though it is generally best to not have a very long extension between the matchbox and receiver from a power delivery standpoint, it is better to have multiple extensions between the matchbox and servos, than 1 long extension between the matchbox and receiver. You might also try different servos to see if it is a servo problem or a servo compatability problem.
_____________________________
Danny Snyder
Horizon Hobby / Team JR
So this is hapenning at this moment in my workshop, I've since swapped the rudder servo for a JR servo and things didin't change. If I pull the antenna out 1 section everything seems to be fine. I'm still unclear why when the matchbox lead is pulled from the TXall is well and as soon as it's plugged in the rudder servo will makes serious movement. I can even create movement by waiving my hand between the radio and the TX. I will move everything outside and determine if this continues.
Thanks for all the responses it''s greatly appreciated I will follow up with further info as to where this goes, it may help others in the future.
